Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 11-18-2006, 08:01 AM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
Removal of Exhaust Flange Gasket
I have a 2002 Pontiac Montana. I am need to replace the exhaust flange gasket. When I unbolt the exhaust flange, nothing comes out. Does the gasket set in an indention that I need to pry it from? Can't see because of where the flange is, so I need to know what to feel for?
Old 11-18-2006, 11:00 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Removal of Exhaust Flange Gasket
Get a new flange gasket and you will see how it is made.
If your old one is burnt out there may still be part of it left in pipe.
Look at new gasket and you will see how it is made.
But some of them do not use a gasket so look it over good.
Good Luck
MT
Old 11-18-2006, 11:02 AM
The reason I thought I needed to replace the exhaust flange gasket is that I hear an exhaust leak. The gasket that I purchased from Advance Auto Parts was some sort of metal. I bolted the exhaust flange back together and started the vehicle. I felt for leaks around the flange and did not feel anything. Where else could the leak/sound be coming from? Thanks for the help.
Old 11-18-2006, 11:07 AM
MT-2500's Avatar
AF - Advisor
Just about anyplace on the exhaust system could leak.
Start it up cold and listen and feel for leakage.
Sometimes there will be a black spot around the leak.
If all else fails run it by a muffler or repair shop and see if they can spot the leak.
MT
