Old 11-18-2006, 12:03 AM
fordmike fordmike is offline
overdrive issue on 98
I have a 98 SE and I can't get the overdrive button (on the gear shift) to take therefore stuck in lower gears. Does anyone have a suggestion how to fix this problem?
Old 11-18-2006, 10:56 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: overdrive issue on 98
Are there any other indicators? Does the OD light come on or flash? If it doesnt do anything at all, first check all the fuses and then the switch and then the solenoid in trans. Also all the wiring between. Sounds stupid, but check adjustment of brake switch also.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-18-2006, 11:50 AM
Yes, the OD light off flashes once I get to the correct speed.
Old 11-18-2006, 04:37 PM
way2old's Avatar
TOKEN HILLBILLY
You need to have the PCM read for codes. It is possible there is a problem with a solenoid or wiring. If wiring and solenoids are OK, then the trans may need to be rebuilt.
