Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-17-2006, 11:59 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Question What is dwell?
Okay, another question I saw in someone else post... What is dwell? I know I own a dwell meter (actually my fathers), but have no idea what dwell is. I used to think it was something with the timing, but I saw dwell adjustment on a carb thread.
Old 11-18-2006, 01:27 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: What is dwell?
A dwell meter's primary purpose is proper adjustment of contact points on an old breaker-point type distributor.
Dwell is duty cycle, on-time. When you set up a carburetor such as an E4ME, it is used to check the duty cycle of the M/C solenoid. When you set the dwell meter on the 6-cylinder scale for a carb adjustment, a dwell of about 30 degrees is equal to about a 50% duty cycle, in other words, the solenoid is engaged 50% of the time.
On the old small block Chevy with breaker-point ignition, you also would want to set the dwell angle to 30 degrees, meaning the points were making contact for 30 degrees of crankshaft rotation.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
