Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-17-2006, 11:39 PM
dapump dapump is offline
help with build?
hello im JAy
thx for reading this
i have a 95 civic coupe
im runimg stock rite now but its been turbo'd for 2months
i want to beef up the bottom
i want to bore it out to i think it was .50 over
d16a6 block stock i want to build it up for more HP
i have
v-tec head
t25 turbo
log manafold
and more goodys
nice set up it runs good
for the new set-up
what kind of rods should i use?
rods inner diameter? what bearings?
crank dememsions? what bearings?
thrust bearings?
do i need to get a better timing belt or is stock good?
what kind of(for low conpresion) head gasket should i get?
since i want to bore it out..
what size bore should i do?
what size pistons should i get? what kind?
low conpresion?
should i get the crank, machined? knifed? edged?
will i need block support/guard?
wich is better e-man or hondata?
do u know where i can get the software for the hondata?
i have both rite now
anything else?
will add more info when im not half a-sleep
Old 11-18-2006, 01:15 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: help with build?
www.turbod16.com can help you out immensely
ask about Vitara pistons
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-02-2006, 08:07 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
research is the key
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-04-2006, 12:49 AM
Originally Posted by superbluecivicsi
research is the key
ya i nkow thats y im here
Old 12-05-2006, 02:16 AM
Schister66's Avatar
AF -Advisor
just for the record, T25's suck.....get something larger and make more power
