help with build?
hello im JAy
thx for reading this i have a 95 civic coupe im runimg stock rite now but its been turbo'd for 2months i want to beef up the bottom i want to bore it out to i think it was .50 over d16a6 block stock i want to build it up for more HP i have v-tec head t25 turbo log manafold and more goodys nice set up it runs good for the new set-up what kind of rods should i use? rods inner diameter? what bearings? crank dememsions? what bearings? thrust bearings? do i need to get a better timing belt or is stock good? what kind of(for low conpresion) head gasket should i get? since i want to bore it out.. what size bore should i do? what size pistons should i get? what kind? low conpresion? should i get the crank, machined? knifed? edged? will i need block support/guard? wich is better e-man or hondata? do u know where i can get the software for the hondata? i have both rite now anything else? will add more info when im not half a-sleep |
Re: help with build?
.50 is impossible. If you meant .050 then yeah, but that's still big. If you throw a rod you don't have much metal left over to save the block. I'd recomend between .020 and .040. For everything else, search. You'll find answeres.
