Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-17-2006, 04:01 PM
Sitruc_bc Sitruc_bc is offline
Send a message via MSN to Sitruc_bc
Troubleshooting tips?
My 85 300zx n/a will not fire up. When I turn the key, the engine rotates, but it won't turn on and stay running. I think the timing is off, but I'm not quite sure. Any suggestions on what else could cause it?
Old 11-17-2006, 04:58 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Troubleshooting tips?
check the timing, check for fuel and spark... see if you can hear your fuel pump humming for 5 seconds after you turn the key to the 'on' position... what happened when it stopped running? did it just die? has it been sitting for a while? when was the last time you did a tune up on it?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 11-18-2006, 07:57 AM
Well, I bought this Z from a friend who bought it from an auction in a city about two hours away from where I live. He didn't have time to work on it, so I bought it from him. He said he drove it home from the auction, but it needed new head gaskets, because he thought the gaskets were blown. So he started to rip stuff apart without a manual. The gaskets looked fine, but I believe there are cracks in the exhaust manifolds, so that's probably why he thought exhaust gas was leaking. Everything is now pretty much put together, except for some jimmy rigged breather hoses for the valve covers, but I am ordering the correct hoses from a nissan dealer. It sat for a year I'd say. When we were working on it, we replaced the oil, oil filter, spark plugs and wires, belts, and I think it's about it. I tried turning it over, and the engine rotates, but won't keep turning. My dad said he could hear fuel running from the lines. Does gasoline get old after a year and has no combustion left? Let me know if I left anything out.
Old 11-22-2006, 01:30 PM
mwolvin mwolvin is offline
the shelf life of gasoline is pretty short. (something like 6 weeks before it starts to turn.) Follow DeleriousZ's advice to start, also pull out a spark plug and smell it. If the gas is bad, it will smell like varnish instead of gasoline. I'd also do a compression check while you have the plugs out.
Old 11-25-2006, 11:10 PM
NissanDatsunDriver's Avatar
NissanDatsunDriver NissanDatsunDriver is offline
Hey, and if it sat for a year, check for rust on the undercoating. Mine sat for a few in a yard and now theres a hole under the driver seat.
