Old 11-17-2006, 02:56 PM
wrheiseae wrheiseae is offline
Geo Metro No Spark--No Start
Hey my geo metro recently had it's engine changed and after it was replaced we don't get any spark the engine will turn over but it won't spark. We have replaced the ECM as well as the pick-up coil and ignition coil. We picked up a spark tester and are positive there is no spark coming from the ignition coil. Any suggestions?
Old 11-17-2006, 05:08 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Geo Metro No Spark--No Start
check the ground wires that bolt to back of the intake manifold and make sure its there and that the two behind the radiator overflow bottle are there and tight
Old 11-21-2006, 04:02 PM
scooby83 scooby83 is offline
I have a 95 geo ran poorly so I changed the fuel filter,plugs,cap,rotor.My new problem is I was backing it out of the shop and it died no spark changed module and coil still no luck where do I look?
Old 11-21-2006, 05:35 PM
Crvett69's Avatar
take cap off dist and have someone crank engine over to see if your rotor is turning
Old 11-22-2006, 02:27 PM
HannabilRox HannabilRox is offline
On most GEO's I have worked on, there is a thick ground wire that goes from the back of the firewall to one of the bolts on the distributor mount. This ground wire can be "unclipped" in the middle. Make sure that wire is present and plugged together. Also, make sure the distributor signal wire is connected properly down by the rear of the head under the intake manifold.
Old 11-25-2006, 05:08 AM
lilrogue78 lilrogue78 is offline
same prob here basicallt i was leaving my cousins girlfriends house and spun my tires in 1st and all of a sudden it wheel hoped and stalled *poof* gone And checked her out .... no spark no fuel (ditributer turns) tesyed for power at coil and sure thing ... power on both terminals but big thing is when i spun em the rear botor mount bolt fell out and droped the rearr of thew motor about 4 inches..... i checked and didnt appear as tho any wires were stretched(as i could see) so any ideas? i lifted the motor back up and secured it properly Hope i can get some ideas
thank ya
dave
Old 11-26-2006, 03:25 AM
hey, not to be pesky but ANY available help would be AWESOME i checked all the wiring in the fuse panel i tired dumping gas in the intake, oh and i saw somthing weird i tested power at both sides of the coil and they are both hot when ignition is on so i dunno if its supposed to do that or what (and the timing belt is activly working) and on time so i'm confused as hell (this is my daily driver and i have been out a car for about a week now so any help is extremely appreciated, thank you , dave
