i have a 97 lumina, the dash, ash tray and heater control lights are out. radio ,interior lights work.. i have checked all fusses . could the dimmer switch cause this? any help..
Re: dimmer switch?
The bulbs are probably blown. This is fairly common on an "older" vehicle. If the miles are high, then I'd say that's more than likely your problem. It seems like they all tend to go out at once. Replacing the instrument panel lights should be fairly easy. Remove dash cover and it should be self explanatory from there. As far as the heater controls, those may be a little more difficult to replace. The bulbs in my '93 lumina did the same thing. I took the heater control box apart and found that it would be quite difficult to replace the bulbs and get that thing back together properly. I also looked up the replacement bulbs in the owners manual, but couldn't find any place that carried them. I didn't check Radio Shack, so you might try that if you want to mess with trying to replace them. I saved my energy and just got used controls in the junkyard (around $10) and it's worked fine ever since. You run a risk in getting junkyard parts, but the cost is considerably less than purchasing a new one. If/when you replace the box, be sure to put all the wires back in the proper place. Good Luck!
![]() This ain't your grandma's car!!
Re: dimmer switch?
Yes, a failed dimmer control could cause that.
Re: dimmer switch?
Re: dimmer switch?
See if you have 12v into the switch, if ok jump across the terminals and if the dash lites come on, replace the dimmer, they were problematic on that car to begin with. There is now way without a major voltage surge when the lites were on that all the bulbs burnt out, as was mentioned.
Re: dimmer switch?
OK, I was wrong. BUT!... I still stand by my statement that it seems like all the bulbs tend to go out at once!
I have one question: What is the ash tray light?? I don't have any lights down there except the ones on my [floor mounted] gear shift.
Re: dimmer switch?
Re: dimmer switch?
Check this link to get at the dimmer/h'lite switch. http://autozone.com/servlet/UiBroker...3d800ed94f.jsp
Re: dimmer switch?
also you said that you have a floor shift, i dident know they made floor shifts in the secound gen luminas. ive never seen one.
Re: dimmer switch?
Only in the 98-99 LTZ's I believe.
Re: dimmer switch?
Re: dimmer switch?
My '96 Lumi is about as plain as you can find. It has no power windows, no power seats, no ABS, no remote entry, manual mirrors, not much of anything, but it does have a light in the ash tray.
The radio lighting (including the digital display) should also be tied to the dimmer control. If the clock/radio display goes out, it's almost certainly the dimmer control. |
Re: dimmer switch?
Re: dimmer switch?
My '96 Lumi is about as plain as you can find. Granny Blue. It has no power windows, no power seats, no ABS, no remote entry, manual mirrors, not much of anything, but it does have a light in the ash tray.
Re: dimmer switch?
Blue, check it out, the 96 Lumina had abs std didn't it?
