Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-17-2006, 12:50 PM
mikesimz mikesimz is offline
Rumble strip noise from front of car
I have a 1996 Bonneville that will randomly make noise from the front end which sounds like you are running over rumble strips. You can feel it through the steering but not bad. I just had the front end aligned and everything is tight. The car does have traction control but it does not matter if it is on or not.
Old 11-19-2006, 08:27 AM
jdq jdq is offline
Re: Rumble strip noise from front of car
Probably wheel bearing, is it just sound or is it a bumpy ride.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 11-19-2006, 10:15 AM
LMP's Avatar
LMP LMP is offline
Indeed my first thought was wheel bearing...this is a continuous rumbling that accentuates when you turn on one side and lessens when turning the other side. It is also independent of the torque applied to traction..does it as well when coasting. WHeel bearing is quite easy to replace.
THe other not so wanted option is "torque converter clutch" slippage..known as TCC shudder...which shows when torque is applied, disappears when releasing throttle. This can be tested by disconnecting the TCC solenoid at the plug going to the transmission. THis prevents TCC from applying..if noise disappears, you have your response.
Another option is constant velocity joints going haywire....
If you need more details just come back.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
