Old 11-17-2006, 12:47 PM
knucklebuster23 knucklebuster23 is offline
info on control arms
I have a 98 intrigue that need control arm bushings replaced. Do these have to be pressed into place?
Old 11-17-2006, 09:15 PM
panzer dragoon panzer dragoon is offline
Re: info on control arms
Vertical Bushing = Yes
Horizontal bushing is part of control arm = No
J 21474-01 Control Arm Bushing Service Set
J 34126 Driven Sprocket Support Bearing Installer
J 35379 Front Knuckle Support
J 21474-27 Puller Bolt
J 21474 Bushing Installer
J 21474-02 Bushing Installer
J 21474-4 Nut
J 41014-1 Bushing Remover
Make your own with a large hardened bolt, nut and some washers and cups.
Old 11-18-2006, 12:52 PM
J 21474-4 Nut
what are these numbers for? are they for these parts ? how do I get more info? Be pacific.
Old 11-18-2006, 03:40 PM
Control Arm Bushing
Front Suspension
Bushings
GM part #10407903
$9.39 (dealer) about 1/2 off at GMpartsdirect
those numbers are all GM part numbers. You can make your own bushing puller will some hardened metal, and cut pieces of pipe. Harbor Freight has the cups and cheap ball joint and puller sets. The hardened bolt goes thru the bushing (in this case) and pulls the bushing into the cup part. Need a good quality socket wrench and maybe a breaker bar also (a piece of pipe over your wrench handle).
Old 11-18-2006, 06:57 PM
Control Arm Bushing
Front Suspension
Bushings
GM part #10407903
Thanks I got a good idea what's going on now. A mechanic told me that it's best just to replace the whole control arm assembly, He said that if you just replace the bushings you'll be changing them again in another six months. I hope he's wrong. Thanks again.
