Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-17-2006, 12:27 PM
99Cougargrn 99Cougargrn is offline
Question What is wrong?????
Went out to start up My 99 cougar. It started and began shaking, like it was going to stall out at any minute. I let it idle for a few minutes, figuring with the rain we had it just needed that. But no, put it in drive (while it was still shaking like an earthquake) and it obviously stalled out. There is little to no power to the gas when in park. Was out on Wed, and the car has been absolutly fine. Looked under the hood, I don't know what they are called but saw that wires that connect to the engine, towrds the back middle or in front of the windshield (looks like a plug) the yellowy/orange one was completly stripped and torn away. To the right (looking head on at car) Wires are completly ripped off of plug that goes to I think my brake fluid (ouch). My hubby does not think that that is causing the intense shaking and stalling of the car. Though I disagree. Anyone out there that has any idea what this is? Or what the heck happened? Need help!!! Car has just over 72,000 have done reg checks and matainence. Oh yah engine light is on too
Old 11-17-2006, 12:47 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: What is wrong?????
Go to a parts store and get the trouble codes pulled from the computer. Then, post them back here so we can help.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 11-17-2006, 12:52 PM
I live in the booneys, but can when I get another vehicle. Thanks for your reply,really appreciate.
Old 11-17-2006, 01:38 PM
cougar4life cougar4life is offline
Is the check engine light flashing?
Check out newcougar.org/forums It is a board just for 99-02 cougar. Make sure to post a welcome post in the welcome section. Be sure to let people know what state you live in. Maybe there will be someone local that could help.
2001 cougar 2.5V6 AUTO Trubendz catback,SVT uim and TB,K&N intake and someother non performance stuff
Old 11-17-2006, 04:56 PM
no it is steady on
Old 11-17-2006, 08:36 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
can you take a picture of the wire thats torn. I can probably tell you what it is.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-13-2007, 07:49 PM
rhandwor rhandwor is offline
If you know where the wires go install new wires this is a quick cheap test.
Basically you have to start somewhere. Always replace bare wires unless you are certain they are disconnected.
Old 01-14-2007, 10:46 PM
Actually, squirrels had gotten into my engine. They chewed through the cylinder wires and that caused the engine to behave as it did, they also chewed through the (not sure what it is called) that tells my dashboard that somethings up. The light just stays on. Guess it was payback, we had evicted the darn squirrels from our attic and I chased them off the roof so we coud seal up the hole. They are nasty little things, I put mothballs under the hood and everything has been just fine since.
