Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-17-2006, 12:15 PM
260guy 260guy is offline
Problem starting 92 toyota pickup
Hello all,
I'm trying to help a friend get his 92 PU started but it won't. When the key is turned to the accessory position, all electrical inside the vehicle works (radio, interior lights, etc...). When the key gets turned to the on position, all electrical cuts out, nothing, nada. Naturally, the vehicle won't start, it won't even turn over. It sounded to me like a blown fuse but my friend already checked the fuses. I thought it could also be a short in the wiring somewhere. Any ideas? Thanks for the help.
Old 11-18-2006, 12:23 AM
KimMG KimMG is offline
AF - Advisor
Re: Problem starting 92 toyota pickup
Faulty ignition switch? Did your friend use a test light or meter to check the fuses?
Old 11-20-2006, 07:47 PM
oops-sorry oops-sorry is offline
sounds to me like a bad ground, or a poor connection at the battery. more than likely bad connection at battery
Old 11-20-2006, 07:56 PM
MishaA's Avatar
MishaA MishaA is offline
+1 switch
Old 11-21-2006, 03:17 AM
sorry, i didnt read the problem correctly. i thought this was happening while you were trying to crank the engine. i would agree with the MishaA and KimMG on the ignition switch. now you see why i call myself oops-sorry. lol
