Old 11-17-2006, 08:10 AM
Tony Varner Tony Varner is offline
99 ford f250 5.4 liter
my trucks will turn over and sounds like it wants to run for a second and die ran fine last time driven the next day no start, can you help me?
Old 11-17-2006, 08:59 PM
rhandwor rhandwor is offline
Re: 99 ford f250 5.4 liter
It usually is the cam shaft position sensor or a crankshaft position sensor can also cause a no start. You can check with an ohm meter it should go from zero to one when cranking.
Otherwise listen for the fuel pump or use a pressure gage and check pressure.
Old 04-29-2007, 07:13 PM
bearcat329 bearcat329 is offline
Question Re: 99 ford f250 5.4 liter
are you using the factory supplied key in the ignition? or is it a copy? a copy will unlock and start the truck, but it won't run for more then a second or 2, the factory keys have a microchip in them
hth
Rick, Ore
