Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-16-2006, 11:23 PM
EngineandJuice EngineandJuice is offline
Wheel Clearance
Hi this is my first post here but I've read many and have collected so much good info so when faced with the chance to buy some already inexpensive wheels for even cheaper I needed to ask this.
this is the ad for a set of rims...
4 - 15" American Racing Chrome Wheels - Excellent Condition, 5 lugs, - 15x7", 5x4.75" Lug Pattern - Fits the 1989-2005 4x4 Chevy S10, Chevy Blazer GMC Sonoma, GMC Jimmy. May Fit Other Model Years
I was wondering if these would fit a 88' Caprice Classic. What size tires would go on them and would there be a clearance problem in teh front? So far I've been told that they should fit the back with no problem and the lug spacing is right but my concern is the 15x7".
Old 11-17-2006, 12:23 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Wheel Clearance
15x7 is definitely a good size, the 1988 Caprice Classic (excluding most 9C1s) uses the 5 on 4.75" bolt pattern. Your only concern should be wheel offset - everything else should be fine.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-17-2006, 05:12 AM
CD Smalley CD Smalley is offline
Re: Wheel Clearance
Not sure on an aftermarket wheel. But anything for the S-10 became "hub-centric" at some point in there. These factory wheels would require machining to fit over the center hub on the Caprice. Don't know if the aftermarket wheels will have the same problem. Call and get the model number and look it up on American's website.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 11-17-2006, 02:59 PM
Re: Wheel Clearance
Also since i'm on the subject of wheels my cousin has some stock 94-96 (don't know the year or if there's a difference) Impala SS rims on his caprice and he's looking for some bargin tires to hold him over for awhile and we ran into someone with some P245/65R17 Brigestone Dueler H/T 689 I was wondering if those would fit on the stock Impala rims?
