Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-16-2006, 09:45 PM
stevem20 stevem20 is offline
Question mystery oil leak
I have a 95 yj jeep wrangler with a 2.5 engine. I have a oil leak that i can not find where it is coming from. It is on the passenger side of the engine.
It is covering the block and last spark plug wire and running down onto the starter. It appeared to be coming from the base of the dip stick tube but I put a bead of weld around it and its not coming from there. Its also not coming from the head gasket. It appears to be coming out of block somewhere and its a heavy flow but i cant find it. engine runs great but leaks too bad to ignore. Any idea's where I can try to fix next?
Old 11-16-2006, 10:09 PM
bdiamond69 bdiamond69 is offline
Re: mystery oil leak
i just have a question what type welding rod or wire did you weld a steel tube (dip stick tube) to your cast iron block ????
89 jeep wrangler with a 360 amc v8 40 over
msd ignition system from box to wires
edelbrock performer intake, cam
holly fuel inj
k&n air filter
tubro 400 trany with shift kit
dana 44 axles 4.56 gears
all 4 wheel power disc brakes
6 1/2 inchs of suspension lift
rci racing seats
simpson 5 point harness
griffin aluminum radiator
REAL JEEPS ARE BUILT NOT BOUGHT
LIFT IT --- FAT CHICKS CAN'T JUMP
Old 11-17-2006, 06:37 AM
I used a liquid jb weld that a guy at the auto parts store recomended.
Old 11-17-2006, 10:17 AM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
hey i had the same problem and i have the same kind of jeep so heres what was wrong with mine
the oil pressure sending unit(thing that makes the gauge work)
for some reason it was loose and wouldnt tighten down and what ended up happening was that i had to replace it ... there not to expensive and not hard to do yourself.... but your right dont ignore this it will ruin anything that the oil gets on eventually
check this link out
http://www.partsamerica.com/ProductD...pe=417&ptset=A
