Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-16-2006, 09:44 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Max boost on stock bottom end
How much boost would be safe for a stock 7 bolt bottom end with a built head and good headgasket?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 11-16-2006, 09:56 PM
Killa's Avatar
Killa Killa is offline
Re: Max boost on stock bottom end
20 psi ? I saw some run on 25 psi
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-16-2006, 10:13 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Obviously it's going to depend on your turbo, but from the knowledge I have gathered you should be able to max out anything below a 50 trim and not worry about the bottom end. I'm sure somebody will correct me if I'm wrong.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-16-2006, 10:22 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
On a 7 bolt, I wouldnt push it past 350. However, I would (and probably will) push my stock 6 bolt bottom end to ~450.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-16-2006, 11:51 PM
2of9 2of9 is offline
i've seen some guy at the tracks boosting his at 23psi with 110 octane, he had the basic exhaust system, uicp, filter...very suprised that he ran mid 13s all day
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 11-17-2006, 12:01 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I'd push a stock bottom end to ~400 without having to worry. 4g63's are strong ass motors, stock 6 bolts will hold over 500hp.
95 Talon TSI AWD
97 Eclipse GST
Old 11-17-2006, 12:26 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
I don't know about power, I think the record is in the 550hp range.. I'd have to look on Dsmlink fourms, their was a thread about that about a month ago. I day dream most days about getting a dirrect port setup for my 2g. I would love to see If I could get up their in those kind of #'s. Thats about $2000 away for me for the basic supporting mods and parts.. Zex Dirrect port kik, Progressive digital meth controler, cams, clutch. Got the ARP's and Cometic.. Not a real sinario though.. Sigh...
6bolts are fucking stout. Their is a guy here in spokane who happens to be a huge theif, but had his engine and tranny build by Jake Montgumry in Nampa, ID. Who is running a baiscly stock 6bolt bottem end with a Gt42 with a race head and putting down some stitty # at 30psi. He's such a fag.. 6bolts are seriously proven stock blocks though. If I had one, I wouldn't even touch it unless the compression was bad. Just put a new front-case, oil pump and complete t-belt kit including pullies and shoot for the moon...
DSM geek
Old 11-17-2006, 12:38 AM
Jeff Harrington holds the 7bolt record
Hey all, I wanted to share my dyno results with you.
We got the MAF settings, so the car will at least idle.
I am VERY happy with the resluts.
551 FWHP
501 Torque
36PSI of boost
T4 60-1 compressor and T350 turbine with .70 AR comp and exhaust.
272 HKS cams
Lower and 2 sides honeycombs
Straight C-16
60lbs/min of airflow
Timing of only 12 degrees
Stock bottom end
Stock 2G intake
1G TB
950cc injectors
Hacked MAF
MBC
99 GST
10.70 at 135mph
DSM geek
Old 11-17-2006, 12:47 AM
Thor06's Avatar
Jizzed In My Pants
Yikes! That guy has more nuts than me. I do know/know of several local guys that have been pounding 500+ from stock 6 bolt bottom ends for years. I dont want to push it though, I like it when the rods stay intact and straight .
Old 11-17-2006, 01:23 AM
Hey man, even the smallest of motors can break rods. Power doesn't break shit, stupidity does!! (No in my case though )
95 Talon TSI AWD
97 Eclipse GST
Old 11-17-2006, 03:09 PM
NateS's Avatar
I know the hp rating but, I was told high boost causes alot of strain on the motor (duh). I told my friend I was planning on pushing about 24psi of boost or where ever my turbo reaches full efficiency at. He told me not to run over 20psi. This kid used to be a big dsmer so I trusted that he might know a little bit but from my understanding with a built head all I have to worry about is not hitting or going over the 400hp mark.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 11-17-2006, 03:17 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I have been waiting on somebody to catch that. I read your post about max boost and everybody was giving you hp rating. lol
Anyways... I have seen people safely run 24psi on a stock bottom end, so I would assume your safe to that point at least. I'm only gonna run 20psi on the streets with my monster even though I know it'll handle a lot more than that.
Look at it this way. If you run too much boost and mess something up, then it just gives you a good reason to rebuild it stronger.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-17-2006, 03:42 PM
True, but boost and HP are intertwined. You could run 20psi on a t-25 all day but if you slapped on a 60-1 and cranked it up to 20psi, I think something would fly through the hood on a stock bottom end. So I would say 20-25 psi because I doubt you're running a GT35r. What turbo are you planning on running?
95 Talon TSI AWD
97 Eclipse GST
Old 11-17-2006, 07:41 PM
NateS's Avatar
I will still be running the current turbo that is on my car. It has similiar flow charts as a big 16 I believe. We never really identified it. I have ran 24psi once and it pulled a hell of a lot harder and held fine but, that was just for one pull and before my new head/headgasket. I plan on logging the lb/min flow and stop turning up the boost when the flow stops increasing.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 11-17-2006, 07:59 PM
I did post the Boost. It said 36psi on his 60trim. Boost is a stupid way of looking at the question. It's not about boost, it's about airflow. Airflow=power. Their is a mechanical limit to the internals, and it is obviously close to 550hp. What ever "boost" it takes you to get this is upto the turbo you use.
So, I guess the real question is. At what point on what turbo will the mechanical effency of our 7bolt blocks fail?
DSM geek
