Buying 91 Sable???
Hi all. I'm looking at possibly buying a 91 sable for my son. Don't know engine size or what tranny it has. I know it's supposed to have only 75,000 mi. I'm looking for some input on what to look/check for when I go to see it and also does anyone hane personal experiance as to how well the engines/trannies hold up. Thanks in advance for any and all input.
Re: Buying 91 Sable???
Try every feature, heater, windows, doors, locks, switches, etc. Ask to see maintenace records. If not maintained, the transmission is the weekest part of the drivetrain. If possible, have a mechanic look it over
Thanks for the response Kim. Went and looked at the car- what a peice!!!
The 1991 transmissions were a big POS and stay away from if it has the 3.8 under the hood.The 3.8 has problems with the headgaskets costing more than car is worth.If it has the 3.0,that is the good motor and do not die
I disagree, once you get past the head gasket issue, the 3.8 is the best Taurus engine, IMO. Quite a bit of low end torque.
The transmissions are so-so, but keep fresh fluid in them and they aren't that bad.
![]() - Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers - As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee! |
I've put in two transmissions. rebuilt distributor, radiator"old plastic when they go can't be repaired. power steering hoses, numerous motor and tranny mounts.It has had a stalling problem from the time i bought it.replaced motor pulley.replaced starter. and it gets a whopping 14 miles to gallon.It now costs$22.00 to go a hundred miles.
