Old 11-16-2006, 03:10 PM
jackfoxx jackfoxx is offline
1999 Escort Trouble Code
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
Any ideas of where to start looking?
Thanks
Jack
Old 11-16-2006, 05:08 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 1999 Escort Trouble Code
Assuming that no work has been done on the engine recently, your problem is most likely at the sensor. If you have had other repairs done recently, don't assume anything.
Check over your wiring for any damage, and if all checks out, you can be fairly confident that a new sensor will clear it up. Make sure you change the correct one (before the cat converter).
If you remove it and find it all gunked up, a cleaning of it may give temporary results. Since it is a '99, it is probably just due to be replaced.
