Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-16-2006, 02:31 PM
[email protected] Chriznat20@msn.com is offline
90 Cutlass Supreme Door Handle
I just bought a 1990 Cutlass Supreme (4 door) and the outer drivers side door handle doesnt seem to be working unless you yank on it realllly hard and pull the door really hard. It seems the door handles are a common part to replace on these vehicles. So how do you do it?? Any advice for a newby?
2002 Envoy SLT
106,500 miles, AutoRide, 4x4, Navigation
2005 Saturn L300
V6, Chrome rims, Moonroof
44,000 miles
Old 11-17-2006, 05:46 PM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
Re: 90 Cutlass Supreme Door Handle
I'm not 100% on those door handles, but the best advice I could give you is too go have a look at the handle from the outside and inside (remove door panel). A lot of times I've had to learn how to do things simply by going through a logic process. Logic tells us the handle is held on by screws or bolts, therfore look for screws or bolts.
Old 11-17-2006, 07:39 PM
caddyman379 caddyman379 is offline
Pretty straightforward removal for the door panel. Look for any and all screws retaining it to the door, after you have removed all of them, pry along the edges of the panel where it meets the door. Aside from screws, it's held in place by clips. Be careful not to break anything. Plastic breaks easily, even easier if its old.
Old 12-09-2006, 06:51 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
could be just be the rods on the inside, if i remember correctly on the end of the rod, near the lock, there is a little plastic thing, you can turn it, and it'll make the rod longer, so less effort to open the door, its kind of a pain to get to it and make it all work
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
Old 12-24-2006, 10:26 PM
94cutsupreme 94cutsupreme is offline
Send a message via AIM to 94cutsupreme
there's no point in replacing the handle...you'll keep getting the same problem. i had a new handle and within less than a year it was the same way...use some wd-40 or something....just dont waste the money
94 Cutlass Supreme-It went bye bye
95 Cutlass Supreme-Done at 250,000+miles!
05 Nissan Sentra-1.8 SE manual-shittier than I thought it would be
Time to consider a new car
