Old 11-16-2006, 01:02 PM
t_rappster t_rappster is offline
Cold start problems
Has anyone had problem with there truck not wanting to idle only on cold starts, as in when the temp. falls below 35 degrees. Once the engine has generated enough heat it is fine and idles good and is good for the rest of the day. But come next morning after it has sat all night it does the same thing. When the avg. temp is higher like in the summer time there is no problem at all. I have an 01 Z71 with the 5.3L. Where should I look to fix this issue?
Old 11-16-2006, 11:06 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Cold start problems
Take it to a shop and have the coolant temp sensor checked, if it is not reading the correct temp the it will cause this problem. If the cts tells the computer that it is warmer than it is it will not go in to the cold start mode.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 11-17-2006, 07:09 AM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
not enough fuel for those morning starts. Sounds like the fuel regulator. That is a common problem on these trucks.
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
Old 11-17-2006, 09:06 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
You may want to use thiner oil.. When your engine is cold that oil is much like sludge as is harder to move around and can cause rough idling. use 5w30 if you are not already.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 11-17-2006, 12:17 PM
Thanks, I will try these things and see if it helps. I took it to the shop last winter and they couldn't get it to rough idle. So to them it looked good, and without it throwing a code they didn't really know where to look other than to check for vacuum leaks which they found none. I will give these a try. Thanks.
Old 12-10-2006, 06:24 PM
well i got the problem fixed, it was the plenum gasket (intake manifold gasket) another common problem with GM. thanks for the input.
