Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-16-2006, 11:43 AM
crxrookie's Avatar
crxrookie crxrookie is offline
If I dont get my car fixed i'm gonna jerk my hair out!!!!!!!!!!
I'm 27 living in Richmond Va. I've been working on hondas for about 4 years built and raced many but I have a new love the Nissan 240sx. I built 2 crx's one w/ a zc and the other w/ a b16 I've allways wanted a 240 and so I found someone w/ a 91 sport coupe who wanted to trade for my zc. So thats where my problems began. The car ir mint looks great but the crank angle sensor in the distributor was bad no prob. i replaced it then i had to fix the idle prob. i thought it was the spark plug and wires so.... I replaced them. .....no fix. I then decided to check the injectors so i started the car and one by one I pulled the injector wires off to see witch one wasn't spraying if any . Bingo . the # 2 injector wasn't spraying . so i replaced the injector (By the way this is a 91 ka24 W/ the d.o.h.c.) which was a pain in the a@#. When i finshed i started the motor and had the same prob. now the #1 injector isn't spraying .... but the #2 is. What the @#$% Is going on ....... is there an injector resistor box on this motor? or does anyone have any ideas??????????? Please Help Me, I just want to drive my car.
Old 11-16-2006, 04:37 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: If I dont get my car fixed i'm gonna jerk my hair out!!!!!!!!!!
fuel rail??
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 11-16-2006, 05:20 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
check the wiering on the injectors!
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 11-17-2006, 01:37 AM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
could be a bad injector clip somewhere.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 11-19-2006, 05:29 PM
crxrookie's Avatar
I replaced the fuel rail along w/ all of the injectors w/ a doner part from a friends 240 ka dohc in which 2 of the injectors on the rail had allready been replaced. The doner part was in working condition when it was removed.
I have not completely checked the wireing. When I first started to work on the car all but the #2 Injector would spray , now w/ the doner part installed All but the #1 injector will spray. So I don't think it is the wireing or the clip on the injector.
Is there any part on the dohc KA24 that sends signal to the injectors telling them when to spray? (allmost like a injector risistor box on a honda?)
Please Help I want to drive my 240 not a honda!
You know whats mest-up even the nissan dealer here in rich have no idea how to help me, I refuse to give up!!!!!!!
Old 11-19-2006, 05:47 PM
bad ground?
1988 conquest TSI
Torque wins races!
Old 11-19-2006, 05:59 PM
crxrookie's Avatar
I don't think so good ? though I'll double check. Could the timeing being out make the car miss-fire?
It really confuses me because the car miss-fired at first because the #2 injector would not spray. Now that the bad injector has been replaced the #1 injector will not spray makeing the car miss-fire the same way.
Old 11-19-2006, 08:47 PM
if the injector isnt firing, then i would assume it has to do with something other than timing. Sounds like an electrical problem. You could take the injectors down to an injection shop to have them tested real quick to make sure they all work.
1988 conquest TSI
Torque wins races!
Old 11-20-2006, 03:59 PM
slideways...'s Avatar
slideways... slideways... is offline
to answer your other question, the injector signal comes directly from the ECU. theres no magic box. try switching #1 with #4 or something and see what happens.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
