Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 11-16-2006, 08:23 AM
sassybee sassybee is offline
Question a-body,g-body interchange
I have a 1983 elcamino thats needs a front clip. I have located a 1980 monte carlo front clip to replace it with. Up till 1980 the monte carlo was on an a-body. Will the monte carlo clip fit the el camino which is on a g-body without any modifications?
Old 11-19-2006, 08:58 AM
graymarki graymarki is offline
Re: a-body,g-body interchange
What do you mean by front clip? Do you mean core support, header panel, fenders and hood?
graymarki
Old 11-20-2006, 07:53 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I don't think the hood or fenders will fit the El Camino, due to the design of the sheet metal.(It would look interesting though.) If you can find an older edition of a Hollander interchange manual, it should tell you what body parts are interchangeable between the corporate brands. Some salvage yards may have these books that cover that time period and may be able to give you a clearer answer.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 11-21-2006, 10:16 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
There's that, plus the Monte Carlo has been a G-body during the duration of it's RWD lifetime. There are not many differences between A and G, mostly in the sheetmetal, the frames are the same.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-27-2006, 12:51 PM
frogman6042 frogman6042 is offline
only thing i could think is the radiator support would be diffeant but if you pull the front clip do it all together and when you set it up there you will see any differance in the mounts on frame right away i just got done getting parts off an 84 monte ss for my 80 elkieas far as i could see every thing the same other than body lines
Old 01-08-2007, 06:21 AM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
I did this for my 78, the fenders didnt line up, neither did the inner fenderwells, it was easier to get an EC front clip then fab and fab to get the MC one to fit.
And i do beleve its only the 85-87 mc front end that fits perfectly. I could be wrong.
A bodies were the velle.bu and MC end of the 60's beginning of the 70's and G bodies came in in 1978 I believe. try a regal or gn front end, might fit better.
Old 01-26-2007, 05:12 AM
1badelky's Avatar
1badelky 1badelky is offline
not sure on the older monte carlo but i know the that mid 80's will interchange here's pics of my 1981 with a choo choo custom package (hood, fenders,nose,core support,and ,DOORS,AND QUARTER PANEL BODY LINES)FOLLOW LINK http://www.myspace.com/102915879
Old 02-15-2007, 05:42 AM
SolRaven's Avatar
SolRaven SolRaven is offline
Keep in mind that if tag on the door says 84 if its after aug its probably an 85 model. 82-88 Monte Carlos were g body. An 82 should "fit" if you change the hood, fenders, radiator support etc. But 80 is to erly.
Old 05-06-2008, 08:15 PM
karnevil9 karnevil9 is offline
I have a 1978 monte carlo, can i put parts from an a body onto it without having to modify and body parts?
Old 05-07-2008, 12:00 AM
Welcome to AF. Please check the date of the last post in the thread and avoid replying if that date is longer than 3 months from the current date.
It would be better to start a new thread and link to the old one in your new thread.
Closed.
