Old 09-14-2002, 12:10 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Help my hatchie
The other day i started my car and the check engine light came on. it was way screwed up cuz it was idling at 2,000 and whenever i got over 3,500 it wouldnt push any farther. I drove it down the road, shut it off, then started it back up and it was fine. It did it once more since then so i restarted it and it was fine again. Whats going on with it??? Please help me. The engine has 200,000 miles on it but i cant afford a swap just yet. Is this the beginning of the end of my engine?
Old 09-14-2002, 12:19 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
did u check the ecu to see what code its flashing?
http://www.geocities.com/motorcity/s...5/ecucode.html
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 09-14-2002, 12:23 AM
no not yet. Do i have to check that while the check engine light is on? cuz it only does it every once in a while
Old 09-14-2002, 12:27 AM
H4Bangin's Avatar
pull the carpet back and look how many times the LED blinks
Old 09-14-2002, 12:38 AM
what carpet? i mean, wheres the LED
Old 09-14-2002, 12:46 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
pull back the passenger carpet, where you feet rest. under the carpet there is a metal cover, idk if you can see the ecu light from there, if you cannto the you gotta take off the 4 bolts that hold the metal cover on. once the cover is removed, youll be albe to see the ecu light
Old 09-14-2002, 12:53 AM
only once. does that mean that it doesnt detect anything wrong?
Old 09-14-2002, 12:59 AM
well, it blinks once when the key goes to the on position. is that it just turning on or is that an oxygen sensor code
Old 09-14-2002, 11:33 AM
johnnym's Avatar
johnnym johnnym is offline
Have you ever changed the timing belt? I has the same problem and ignored it since all I would have to do was turn the car off and then on again and it would run fine. Of course a month later 'snap' the timing belt broke.... No bent valves which I was lucky but you should change the belt every 100,000 kms...
Old 09-15-2002, 12:40 AM
just replaced it 900 miles ago
Old 09-15-2002, 06:09 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
This sounds to me like a timing or distributor issue. Maybe your timing belt has slipped a tooth or something. Maybe your distro is fried.
Stop looking at my Autometer!
Help with new car audio; Cade.Garrett Car Audio 2 07-02-2009 12:32 PM
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
jdm h22 help sanchezjarodsdad JDM Motor & Parts info/chat 4 04-09-2009 05:14 PM
97 ram 1500 sport 4x4 tranny problems HELP ME! tabes Ram Pickup | Ram SRT10 3 03-14-2009 08:56 AM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
