Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-16-2006, 02:07 AM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
2.5L Power/Milage Modification Recommendations
I recently purchased a 2001 Wrangler with a 2.5L engine. I have already added a magnaflow muffler, left the stock manifold on (sounds beefy). Also installed a throttle body spacer, cold air (K&N) intake filter, and the high spark ignition system. So far these changes have increased power and milage, but I am always looking to better the 2.5L engine.
Short of installing a supercharger (that costs too much) what other installations would you recommend to my Jeep to increased power and milage.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
Old 11-16-2006, 07:28 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: 2.5L Power/Milage Modification Recommendations
This may just be my suggestion since I've been driving 4cyl sport compacts all my life, but the cheapest way to get power out of a 4cyl (especially one with 2.5L) is to add nitrous. Check out the Venom system:
http://www.venom-performance.com/nf/html/r500.cfm
This is a programable system, and would allow you to create a power curve just like a supercharger (not adding 50hp at 1000 rpms... but rather slowly increasing) so you can avoid blowing the engine and get the low end tq that a Jeep needs. I think you can also bore and maybe stroke these engines to squeeze out some more displacement, and cam them (to get the power where you need it). ...That is all cheap assuming you can do most of the work yourself. Gearing is also HUGE with the 4cyl. Ok that's my Time for work!
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 11-21-2006, 04:55 PM
CoriolisSTORM's Avatar
CoriolisSTORM CoriolisSTORM is offline
I've heard of a 2.5L turbo, but I'm not sure of too many that've done it. Supposedly it can be done for about $1400.
Old 11-28-2006, 12:01 AM
4x4grey88's Avatar
I bit much of cost for a 2.5L.
I bit more and I could just change out the engine all together to a Ford 302.
I was looking for modification to inprove with a low cost.
Thanks for your help though.
P.S. I removed my OEM fan over the weekend and installed an electric fan from a Lincoln which increased my HP and speed. The engine is much quieter too.
