Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-15-2006, 11:59 PM
jsweeter jsweeter is offline
Too Lean Air/Fuel mix
I have a 1999 contour se sport 2.5 DOHC. (i like it when people are specific)
I had a problem a little while ago as you could see back i had to replace the IAC on this car. When the IAC was messed up I kept getting the Too rich code on the ODB-II reader. Now I replaced the IAC and also gave it a tune up. I put the Bosch Platinum II plugs in it. About 2-3 days later the light came on and the reader said that both banks (1 & 2) were running lean. Is this in contribution to the new spark plugs or do you think I have another problem? Thanks in advance for your help.
Old 11-16-2006, 12:34 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Too Lean Air/Fuel mix
First of all, the bosch platinum plugs are definetely not recommended for the duratec V6. This topic comes up at least once a month on CEG so I'll let you read why.
http://www.contour.org/ubbthreads/sh...rue#Post112598
Definetely not a spark plug problem. If it were the plugs, it would be a rich code since they would be giving an insufficient spark.
What did your tune up consist of?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-16-2006, 08:14 AM
reekor reekor is offline
What kind of an air filter do you have in the car? If it's an oil charged filter toss it and clean your MAF (Mass Air Flow) Sensor.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 11-16-2006, 08:34 AM
cougar4life cougar4life is offline
Maybe a vacuum leak somewhere allowing unmetered air into the combustion chamber.
2001 cougar 2.5V6 AUTO Trubendz catback,SVT uim and TB,K&N intake and someother non performance stuff
Old 11-17-2006, 12:22 PM
where can I get the motorcraft platinum 2 plugs? Is this straight from the dealer?
The air filter is not oil charged but taking apart the rest of the air intake the MAF is okay but behind that there is some noticeable oil on the bendable hose, like it is coming out of one of the breathers from the valve covers.
Old 11-17-2006, 05:28 PM
Yes, from the dealer.
Oil is normal after the MAF since the PCV vents into the accordian tube.
"The CEG Nazi"
www.contour.org
Old 11-18-2006, 10:43 AM
Okay, i'll get some new plugs and try to see if I can find an air leak. Maybe I didn't get the bolts for the IAC all the way tight.
Old 11-18-2006, 11:03 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
You can buy Motorcraft plugs from just about any aftermarket parts house.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-22-2006, 12:41 PM
found 1 of the bolts loose on the IAC. When i replaced it must not have got them all the way tight. Changed plugs but plugs did not change the way it runs. Cleared the codes, i'll see if it comes back.
Old 11-22-2006, 12:49 PM
if indeed there was an intake leak at your IAC, that would certainly cause the lean code you were getting.
"The CEG Nazi"
www.contour.org
Old 11-23-2006, 11:18 AM
sparkslg sparkslg is offline
2.5 L has a problem with intake manifold gaskets that leak
if you can read data stream from your code reader look at long and short term fuel trims while spraying brake clean around intake (both upper and lower) gaskets , i'm sure you will see them change if they change usually go all the way negative , this is very common , replace both sets of gaskets
also Ford has a TSB on lean and rich issues related to the MAF sensor which is also very common
Old 11-25-2006, 07:42 PM
I haven't had a problem with it now all week. Think we got it.
Thanks guys
