How hard is it to change a battery on a 2002 venture. I'm not a mechanic and have limited mechanical skills.
Re: 2002 Venture - Changing battery
It's not very hard, just hard to get at and time consuming. Click on this link :http://www.automotiveforums.com/vbul...d.php?t=333096 and scroll down to the fourth post for detailed instructions on how to R&R a battery. Good luck. If the battery is not totally dead yet, and you can drive the van. you might want to call some of your local auto parts retailers to see if they offer free installation with battery purchase.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Thanks for your reply. Is there anyway to know for sure it is the battery and not the alternator. The van is a 2002 and I'm the original owner and the battery is still the original battery. I can boost it and then it will be okay for a day or so and then it will need another boost. I'm going to try to change it myself following your directions. I will keep you posted.
If you have one post the battery voltage engine off and then engine running.
Either way though, first jump it if it needs it, drive it to an Auto Zone, Kragen, Pep Boys, and have them do their free system check where they roll a test cart out that checks your entire charging system and tells you which part (battery, alternator, etc) is bad. Like the other guy, find the root cause before you start replacing. It is always good to have your alternator checked to make sure that it is putting out the proper amount to the battery. |
