Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-15-2006, 07:54 PM
YankeeHick YankeeHick is offline
Send a message via Yahoo to YankeeHick
Unhappy 91 caprice alternator question...
i'm using a 305 from a 91 caprice in my 78 Grand Prix. i'm ready to connect all the wires, but i've got this problem.... which wire on the main connecter is which? there's 2 wires coming off of the pigtail. i'd rather not short it out, ya know? thanks!
Old 11-15-2006, 07:58 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 91 caprice alternator question...
Delphi CS series alternator? i.e. CS130 ... The big red wire is the charge wire, and the brown wire is the field wire (runs your idiot/warning light). The red wire on the terminal in the back goes to the battery, similar to the older 10/12SI alternators.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-15-2006, 08:44 PM
not sure what series of alternator is in there. all i know for sure at this point (car's not here) is that there is a small, 2-wire plug that goes into the top, and has 2 wires. i think there's a label on it that says something like FS and something else. does this make sense, or am i on crack?
Old 11-15-2006, 09:43 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
I think if anyone knew if you were on crack or not, it'd be you. It makes perfect sense, my '89 GMC has the exact same thing... Anyway, I'd check this with silicon, but couldn't you just run the red (main) wire as the normal charge wire to the battery, and simply cap off the secondary brown wire?
Old 11-15-2006, 11:04 PM
silicon212's Avatar
Confoundingly Lucid
You could even wire these, as with the older 10SI units, to run as single-wire, the red wire to the battery only. The main reason for that brown wire IMO is the alternator light on the dash.
