Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-15-2006, 04:28 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Clutch decision
So I am faced with making my clutch decision much earlier than I expected. There is a local guy that took the 2600 that came in his car out. Well, the disk was shot, thats why it was slipping under higher boost. Well, where the disk is worthless, he said the pressure plate is fine and should be ok if you were to just buy a new disk. Well, I can get the pressure plate for pretty much nothing and a new sprung pucked clutch from extreme psi (my new favorite shop) is between like $110 and $125. Then the throw out bearings are only $20 so I will be getting a 2600 clutch setup for like $150-$170. Considering that new 2600's from extreme psi with the sprung 6 puck disk are like $460, I am willing to take a little bit of a chance on a used pressure plate. Oh yeah, I know people with the alignment tools, I wouldnt need to buy my own. My first question: Would you guys trust a used pressure plate? It looked ok in the pictures, but if I were to go and look at it, what would I look for for excess wear?
Ok, second round. For the disk. See, I dont want a street disk. I've driven a few pucked clutches with sprung centers and I cant handle them just fine. Well, if you look at the sprung pucked disks they have a 4 puck and a 6 puck. Which one would be best? Heres what I gathered:
4 puck - $110, quicker shifting due to reduced weight
6 puck - $125, for better engagement and better heat capacity
So I think the sprung 6 puck would be best for me, what do you guys think?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-17-2006, 04:09 PM
Thor06's Avatar
Jizzed In My Pants
Re: Clutch decision
No one has two cents to throw at this?
Anyway, I changed my mind. I found a SBR 3500 pressure plate that looked a hell of a lot better than the 2600 PP and it was only $100. I am going to go that route and get a 6 pucked sprung clutch for it (ACT disks will work with it).
Old 11-17-2006, 05:20 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Clutch decision
Well its a little late it seems but when you check a used pressure plate you just want to make sure there isnt any excess warping...you want to make sure its a flat surface...And I would double check to make sure the ACT disks will work with that pressure plate..from what I hear its bad to mix and match with clutch assemblys...and also I am just curious as to why you are getting a puck disk??
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 11-17-2006, 05:56 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Clutch decision
I just skimmed through reading your post, but things to look for are heat marks and such. I found out my pressure plate is no good anymore, so now I need to get a new one too for my brand new disc.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-17-2006, 06:36 PM
Killa's Avatar
Killa Killa is offline
Re: Clutch decision
How big is your left legs ? cause I drove my friend lancer and the car die couple time, my leg suck with that heavy clutch, I think it was 2900 or 2600
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-17-2006, 07:02 PM
Thor06's Avatar
Jizzed In My Pants
Re: Clutch decision
Ha ha, yeah, I can handle a stiffer clutch killer. 7-8 years of lifting, running, and biking does that to ya. ~320lb squat bitches .
Old 11-17-2006, 07:21 PM
Killa's Avatar
Re: Clutch decision
Good to know bitchet .
GM FOR LIFE !!
95 camaro lt1
Old 11-17-2006, 08:49 PM
NOFX0617's Avatar
Re: Clutch decision
Everyone talks about how the 2600 needs a strong left leg...but on my car its not that bad....I mean its a little stiff but not so bad as to complain about it...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 11-18-2006, 01:24 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Clutch decision
I'm a lazzy pussy and even I can handle the 2600.. If people don't want to have stiff peddle or increased pressure tell them not to build a fast car..
DSM geek
Old 11-18-2006, 07:06 AM
Killa's Avatar
Re: Clutch decision
That not my point, my point is i never use 2600 on my car before, I drive it, but I dint drive it every day to get use to it, if I have it in my car in a week I will get use to it. First when I just learn how to drive stick, my friend acura intergra ( speel ) he had race clutch, and it really heavy and hard to learn drive stick from the first time, then I though every manual car clutch will be this hard to push on. Then I drove the eclipse and feel like butter.
GM FOR LIFE !!
95 camaro lt1
Old 11-18-2006, 09:19 AM
Black Knight 00's Avatar
Black Knight 00 Black Knight 00 is offline
Send a message via AIM to Black Knight 00
Re: Clutch decision
im not sure if i would trust a used pressure plate. i would take a level to it or take it to a machine shop can make sure its flat. ive heard horror stories of plates going back and only burning up part of the clutch.
Will Work For Boost!!!
Selling 2000 Eclipse Gs
Looking for 1999 Eclipse GsT Spyder
