Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-13-2002, 10:26 PM
95cvccvx 95cvccvx is offline
coil over adjustment
I had some coil over installed in my ride about a yr and half ago. Now i want to raise the back of the car. When adjusting the perch should i raise it or lower it. When i raise it, it looks like the spring becomes smaller and when i drop the perch it looks like the spring goes higher and im thinking that its raising the car. I should already the answer, but dont please help.
Old 09-14-2002, 03:08 PM
delsolsi delsolsi is offline
Raising the perch lifts the spring, the spring is what holds the car up, so this also lifts the car. Same thing in reverse for lowering.
Old 09-15-2002, 03:15 AM
Thanks for your help. I adjusted my car already and it was simple. once again thanks
coil over shock or no coil overs big white bufflo AMC 1 02-06-2025 01:22 PM
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 06:03 PM
Lowering springs, adjustable coil overs vette_7t9 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-20-2006 04:57 PM
can't adjust coil overs? RoBoDEATH '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 07-03-2002 11:44 AM
