Old 11-15-2006, 02:26 PM
shadow163 shadow163 is offline
fixing a manifold coolant leak
I took my 98 lumina in yesterday to have a new fuel regulator put in. while it was there they found a coolant leak on the manifold. i forgot to ask where it was exactly but the guy told me that i could get away with driving it around for a while with out any problems. i did some searching and it seems that there is some problem with the intake manifolds and was curious if this was something i could replace myself without too much work or if it would be worth the 900 dollars they said it would cost to fix it.
Old 11-15-2006, 03:58 PM
wafrederick wafrederick is offline
Banned
Re: fixing a manifold coolant leak
Get the intake gaskets replaced asap.You do not want to burn the engine up.
Old 11-15-2006, 09:34 PM
chubbygoatboy chubbygoatboy is offline
You want to get it fixed, and have them flush out the entire system to get rid of Dexcool, and replace it with good ole green antifreeze. BTW, I only charge $600 to do this complete job!!
Old 11-15-2006, 11:02 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Damn, I only charge $300. I've got it down to a 4 hr. job. Gettin good at these 3X00 intakes...
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 11-16-2006, 11:45 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Is your car a 3.1 or 3.8? Each engine has an intake coolant leak issue, but are different. The 3.1 intake leak is a bad gasket that allows coolant to get in the oil, the 3.8 is a defective upper plenum which allows coolant into the cylinders, both which can lead to catastrophic engine failure. Don't put this job off, do it ASAP.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
