Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-15-2006, 12:11 PM
leistef leistef is offline
Transmission Range Sensor P0708
Need to change a Transmission Range Sensor on a 2000 Cougar, 2.5ltr and of course I can not find a manual.
Can anyone tell me if I should put transmission in N before I change or is this just a plug-n-play sensor.
Thanx in advance.
Old 11-16-2006, 05:57 AM
cougar4life cougar4life is offline
Re: Transmission Range Sensor P0708
I would recommend going to newcougar.org. There are a lot of 99-02 cougar experts over there.
2001 cougar 2.5V6 AUTO Trubendz catback,SVT uim and TB,K&N intake and someother non performance stuff
Old 11-16-2006, 08:29 AM
reekor reekor is offline
Transmission Range (TR) Sensor (177050)
Special Service Tool(s)
Gauge TR Sensor Alignment 307-271
(T94P-70010-AH)
Removal
1. Disconnect the batterie ground cable.
2. Position the gearshift lever in NEUTRAL.
3. Remove the battery tray.
4. Remove the transmission range (TR) sensor.
1 Disconnect the TR electrical connector.
2 Remove the bolts.
3 Remove the TR sensor.
Installation
1. Note:
Make sure the transaxle is in the NEUTRAL position.
Position the transmission range (TR) sensor and loosely install the bolts.
2. Note:
As necessary, move the manual control lever to N position for TR sensor adjustment. Rotate the manual valve detent lever assembly to the Neutral position.
1 Low 1
2 Low 2
3 Drive
4 Neutral
5 Reverse
6 Park
3.Install the TR sensor.
1 Using the special tool, align the TR sensor.
2 Tighten the bolts and remove the special tool.
3 Connect the electrical connector.
4. Install the battery tray.
5.Note:
When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Connect the battery ground cable.
6. Check the proper operation with parking brake control engaged. The engine should start only in PARK or NEUTRAL. Reversing lamps should active only in reverse position.
Thanx in advance.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 12-10-2006, 01:47 PM
cf3377 cf3377 is offline
you can also put the car in reverse and then move the sensor till the reverse lights come on
