Old 11-14-2006, 10:50 PM
calvinf117 calvinf117 is offline
93 Taurus Water Pump Help
So me and a few friends of mine set out to change the water pump on my car. We have removed all the bolts to the actual water pump but havent removed the pully for the belt. Do i need to remove this to get the water pump out or do i need to do something else that im missing. Any help would be appreciated. Cause the pump itself doesnt have any give in it at all and im not sure why.
Thanks
Old 11-15-2006, 10:25 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 93 Taurus Water Pump Help
I don't think I've ever done a water pump on a '93, so hopefully someone else will chime in.
That being said, it wouldn't surprise me if the reason there's no play in the pump yet is because the gasket was "tacked" to the pump and some sort of RTV gasket was used between the gasket and the block during a past water pump change. Those two items have glued the pump to the gasket and the gasket to the block. A couple of taps from a dead blow mallet will probably break it loose. Then you will need to be very certain you get all gasket surfaces completely clean before installing the new waterpump.
-Rod
Old 11-16-2006, 10:08 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Taht's what I was thinking as I ahven't done my 92's (yet ), but in general, a RTV'd gasket gets heat baked on pretty well.
Old 11-16-2006, 03:04 PM
Thats pretty much what it was. Broke loose with a hammer got the new one in runs great. Thanks for the help
Old 11-16-2006, 05:31 PM
shorod's Avatar
SHO No Mo
Thank you for the follow-up, and congratulations!
-Rod
