Old 11-14-2006, 10:20 PM
chevyolds chevyolds is offline
Send a message via MSN to chevyolds
1999 jimmy fuel pump wiring
I am hoping some one out there will know what all the wires are to the fuel pump. really only the ground. i want to run a new ground but i am not sure which one it is
any help would be great.
Old 11-15-2006, 06:03 PM
twistedtech twistedtech is offline
Re: 1999 jimmy fuel pump wiring
I dont run a new wire I simply run a a ground from the corner of the tank to the frame.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 11-15-2006, 09:06 PM
wirenut699 wirenut699 is offline
I checked my diagrams for my 1999 blazer.
According to those diagrams the fuel pump has 4 wires: two for the pump and two for the level sending unit (float).
The vapor pressure sensor is three wires: Black/white, grey, dark green
The pump wires are grey(B) and black(C) -the black is the ground. On pickup trucks it grounds to the frame nearby. On SUV's it travels back to the leftside dashboard to a test point and then back to a leftrear crossmember. Seems crazy but I guess if you find the test point under the dash, you can test to see if there is a bad fuel pump ground.
The float is purple(A) and black(D) -this black is not ground. Be careful not to mix the two blacks up.
1999 Blazer LS
1994 Chevy G30 Van
WHY IS THERE NEVER ENOUGH TIME TO DO IT RIGHT,
BUT ALWAYS ENOUGH TIME TO DO IT OVER?
Old 11-17-2006, 05:58 PM
NOTE: the colors I gave previously are for the 4.3 engine. The colors are different if it's the smaller engine.
1999 Blazer LS
1994 Chevy G30 Van
