Old 09-13-2002, 06:32 PM
gwako gwako is offline
2 channel amp
This could be a stupid question, but my question is if I have a two channel amp would I be able to hook it up to both my front speakers and rear speakers, and have control of the fader and the balance....
Old 09-14-2002, 02:00 PM
delsolsi delsolsi is offline
Yes you can hook up both the fronts and the rears if your amp is stable in 2 ohm loads, but you would only have balance control, no fader.
If you want to fade the rears I think theres a way do it with resistors or something. I've never done this or heard of some one doing it but it makes sense in my head, I have no idea if it actualy works though.
Old 09-14-2002, 07:55 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
they make "power faders" that hook to the amp outputs, they suck though. Putting a small value, high wattage resistor inline with a speaker will cut a speakers volume some. The actual DC resistance of a 4 ohm speaker is like 3 ohms, so if you put a 1 ohm (10watt) resistor on it - it will cut the power by like 25%, maybe a 1-2dB difference
Old 09-14-2002, 08:19 PM
strodda strodda is offline
if its not 2ohm stable, although it should be unless its some old fleemarket crap, you can always wire them in series. but that will actually raise the impedence to 8ohms
4 channel amp...4 channel rca ? dh4645 Car Audio 6 07-29-2005 12:00 PM
3 channels into a 2 channel amp mother_russia Car Audio 16 03-15-2005 09:59 PM
Wiring up a 4 Channel AMP 92Accord92 Car Audio 2 04-07-2002 08:01 AM
Good 2 Channel Amp denjam69 Classifieds 0 12-06-2001 09:07 PM
