Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 11-14-2006, 07:44 PM
Bimmere21320's Avatar
Bimmere21320 Bimmere21320 is offline
Tire Question
Hi there everyone, I have a 2003 Tacoma double cab 4x4. I have already installed a 2.5" spacer lift on the front, and an add a leaf in the rear. I was told by the guys at a few local tire shops that I could clear 285/75/16's on my truck. Is this indeed true, and will I have to re-gear my truck? Thanks in advanced!
My 2003 Toyota Tacoma Double Cab
Engine-3.4 V6 with AEM Brute Force Intake
Mods- Westin Bull Bar
-PIAA 520 Ion Fog Lights
-2.5" spacer lift
-Ultra 16x8 Baja Champ Wheels Black in color
-285/75/16 Toyo Open Country A/Ts
-Leer 100R Canopy
-PIAA Xtreme White Plus Headlight/Corner bulbs
-Lund Avenger rock shield
-Soon to come- Imco custom dual exhaust system
Old 11-15-2006, 12:09 AM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: Tire Question
You can fit a 33, but they will rub slightly. You are better off with a 32. You can hold off on a regear until you hit 35s.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 11-15-2006, 01:27 AM
Re: Tire Question
Whew! The way some of these people are talking on here they say that you will need to re-gear if you have anything bigger than a 32. Well, now I don't have to be worried about a re-gear. Yea, the guys at the tire shop said 33's would rub a little, but not bad. Thanks for your help.
P.S. I have a pair of PIAA 520 fog lights that need to be wired up, and the only thing I don't get is the part about tapping into a 12v power source. Can anybody help?
-2.5" spacer lift
-Leer 100R Canopy
Old 11-15-2006, 03:08 AM
KimMG KimMG is offline
AF - Advisor
Re: Tire Question
You need to find a 12v power source that can handle the load for the lights. Look at a wiring diagram for your truck to see if there is an unusedcircuit for fog lamps or you can connect directly to the battery.
Old 11-15-2006, 05:52 PM
TcmaBoy's Avatar
AF - Advisor
Re: Tire Question
You do not need to regear for 33s, but your truck will be a bit slugish (especially if you have the 4cyl) and you will see a drop in fuel econ.
Did they come with a harness, switch, and relay? If not then pick up a headlight harness that comes with those things. Painless makes them.
Old 11-15-2006, 09:14 PM
Re: Tire Question
The lights came with the wiring harness, relay, switch, etc. Everything is there to wire it up, I just need a 12v power source. My truck is a V6 with an automatic so I guess I should be ok.
-2.5" spacer lift
-Leer 100R Canopy
Old 11-16-2006, 12:30 AM
TcmaBoy's Avatar
AF - Advisor
Re: Tire Question
Pull power where the battery meets the under hood fuse box.
Old 11-16-2006, 12:48 AM
Re: Tire Question
So tap into the wire that connects the battery to the fuse block? Sounds good, thanks a lot!
-2.5" spacer lift
-Leer 100R Canopy
Old 11-16-2006, 02:39 AM
TcmaBoy's Avatar
AF - Advisor
Re: Tire Question
No, do not tap the wire. Trace it back to the lug where it connects to the box and use a terminal to connect it properly. Don't forget to hook up the fuse.
Old 11-16-2006, 10:26 PM
Re: Tire Question
So, your saying that I should get a terminal and hook the wire directly into the fuse block? Sorry if this seems hopeless, but I just don't want to screw up the electrical system in my truck, my dad would not be happy.
-2.5" spacer lift
-Leer 100R Canopy
Old 11-17-2006, 12:01 AM
TcmaBoy's Avatar
AF - Advisor
Re: Tire Question
Yep, make the connection where the battery connects to the fuse block. The load will be pulled directly off the battery or alternator. You will have to disassemble the under hood fuse block to get to the terminal lug.
Old 11-18-2006, 05:43 PM
Re: Tire Question
There are two lugs right next to each other, one is where the battery connects to the fuse block and the other one is empty. Can I use the empty one? What do you mean by not forgetting to hook up the fuse, do I need a fuse for the lamps?
-2.5" spacer lift
-Leer 100R Canopy
Old 11-19-2006, 12:23 AM
TcmaBoy's Avatar
AF - Advisor
Re: Tire Question
The terminal right next to the battery hook in is fine.
Yes, you need a fuse for the lights. If your harness doesn't include a fuse then you will need to get one. There should be a reccomendation of the fuse rating in the installation instructions.
Old 11-19-2006, 07:42 PM
Re: Tire Question
The instructions make no mention of using a fuse, but I did successfully hook up my lights and they work! Is it normal for the little green light on the switch to be on even if the ignition is off?
-2.5" spacer lift
-Leer 100R Canopy
Old 11-20-2006, 12:09 AM
TcmaBoy's Avatar
AF - Advisor
Re: Tire Question
Yes, they way it is hooked up it bypasses the ignition. Don't leave them on.
