Old 11-14-2006, 08:22 PM
juggie#1 juggie#1 is offline
Question 2000 Honda accord 4 cylinder
I have just about check everything I'm having problem with #1,2,3 cylinder not firing change Distributor, check injectors, move plug wires around and still do the same thing. Thanks In advance
Old 11-16-2006, 03:35 PM
somick's Avatar
somick somick is offline
Re: 2000 Honda accord 4 cylinder
I see you have been here since December 2005 and still did not learn that the subject line better contain your problem besides your vehicle model!
So, what do you mean by "moving wires around"?
Did you change the distributor cap and did not put wires back in their original order?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 11-16-2006, 04:59 PM
Igovert500's Avatar
blue + red light magnet
Do you have spark, do you have fuel?
Do you have any check engine light? If so, what codes did you retrieve from the ECU? If you havn't yet, Autozone will pull them for free.
Have you double and triple checked that you have the correct firing order?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-16-2006, 10:42 PM
When I said I had move the wire from # 4 spark plug to see if it was the wire that was bad, and needless to say it did the same thing, so what I did was a compression test,and found that the compression was 60 lb, and I ask the owner If she ran the car hot, and the answer was no, so I thank the timing jump or there is a blown head gasket.
