Old 11-14-2006, 06:46 PM
CALPC89 CALPC89 is offline
tranny swap
well i recently messed up my '94 3KGT SL auto. tranny and i was wondering since its already messed up if i could put a vr4 tranny into an sl i know you would have to do other modifications to make an auto. to manual but is it possible to put in a vr4 tranny into a sl???
Old 11-15-2006, 01:39 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: tranny swap
yes, you could put a vr4 (awd) tranny into an SL (fwd) car, but why would you want to? the AWD tranny has longer gears, and since you only have NA power (222hp), then you can't fully utilize the long gears. as a result, you're acceleration will go downhill (esp. in 3rd).
also, FWD trannies are much cheaper than the AWD trannies.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-15-2006, 05:50 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: tranny swap
Fully agreed. Do a 5 speed swap but use a NA tranny. If things go as planned I will have a complete 5 speed swap for sale in a week or two. Keep an eye out for a thread.
Old 11-15-2006, 03:58 PM
Re: tranny swap
i have been told that i need a special linkage to make the computer think its a manual??? is this true or are these places just trying to run up the cost???
Old 11-15-2006, 04:32 PM
Stealthee's Avatar
Re: tranny swap
They are trying to run up the cost. The ECUs are identical MTX to ATX
Old 11-15-2006, 07:09 PM
Igovert500's Avatar
blue + red light magnet
Re: tranny swap
http://www.automotiveforums.com/vbul...08&postcount=3
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-15-2006, 11:10 PM
Re: tranny swap
what about any 2nd gen. 3kgt trannys. would they be able to fit perfectly with all the parts listed on the faq page or would i still need the axles?
Old 11-16-2006, 02:19 AM
Linebckr49's Avatar
Re: tranny swap
i answered this question in the thread on 3si where you posted as well. however, i'll answer it again.
91-92 trannies have smaller differentials. that is, the splines on the inner part of the axles that insert into the differential are smaller. 93+ trannies have larger differentials, or more splines on the inner part of the axles. the spline count on the outer part of the axles is the same for all years (27 splines). however, keep in mind that since the tranny is not in the center of the car, that we have unequal length axles. the passenger side axle is one piece (short side). the driver side axle is 2 pieces (long side). the inside piece on the driver side is called the intermediate shaft, and this is the part that changes. the driver side outer axle is the same for all years. the intermediate shaft differs on its inner spline count (25 for 91-91, 27 for 93+). the outer spline is on the intermediate shaft is the same for all years and inserts into the female end of the driver side outer axle.
so you don't need to get the corresponding year driver side axle, but rather just the corresponding year intermediate shaft. AND, you'll obviously need the corresponding year passenger side axle.
so 2nd gen trannies (93+) require 2G axles (translated 2G passenger side axle & 2G intermediate shaft). 1G trannies (91-92) require 1G axles.
[i know that's more information than what you probably wanted (spline count and all), but that's what i had to go through when i did a tranny swap for a friend. we knew there was a difference, but didn't know what exactly until we searched through CAPS and counted splines and called different auto part stores. we posted in a thread on 3si documenting everything. i'll try to find the link.]
93 3000GT base
Old 11-16-2006, 02:27 AM
Linebckr49's Avatar
Re: tranny swap
as for the intermediate shaft, this is a hard part to track down. you can only buy them new from the dealer (charges ~$500) or from www.raxles.com ($150). the best place to find one is at a junkyard (less than $50).
93 3000GT base
Old 11-16-2006, 02:33 AM
Linebckr49's Avatar
Re: tranny swap
here is my thread on 3si about axle differences between the years: http://www.3si.org/forum/showthread.php?t=352080 ( i say "my" b/c i took it over, damnit! :P)
93 3000GT base
Old 11-16-2006, 12:40 PM
AutostradaVR4 AutostradaVR4 is offline
Re: tranny swap
theres a seller on 3si that would proabaly have the parts you need. mykiss69. runs sort of a 3/s junkyark.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
