Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-14-2006, 06:31 PM
aeflower9 aeflower9 is offline
93 direct bolt on swap
i have a 93 civic what engines bolt directly up with little or no changes thanks
would any of these work D16y7, D15B VTEC, F22B1 SOHC VTEC.
thanks
Old 11-15-2006, 12:59 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: 93 direct bolt on swap
Any D-series will swap over with little to no extra work. Mostly it will just be different wiring for some parts, depending on the year of the engine. Any '92-'95 D-series will swap in with only having to wire up vtec. Any '96-'00 D-series (D16Y7, D16Y8) will bolt up with some other minor changes to the wiring (use existing '93 wiring harness, swap over the voltage regulators in the alternators so that they are the same plug, and swapping over some pins of the distributor plugs). But it also depends on what ECU you're going to be using, you should try to use a '92-'95 ecu if at all possible. Other wise you'll need to buy a conversion harness so you can plug in a newer ecu. '92-'95 has different plugs than the '96-'98 and '99-'00, and the '99-'00 shares the same plugs as the '96-'98 but the wires are different from pin to pin.
The F-series engines are completely different and require the use of a mount kit (h-series and F-series mount kit), which costs around $350-450 for the mounts alone.
Old 11-15-2006, 10:05 PM
will these engines use the same transmission. or do i have to change that also. thanks
Old 11-16-2006, 12:21 PM
CivicSpoon's Avatar
There is no Spoon
Same transmission, mounts, axles, shiftlinkage. You should only need the engine, and an ecu that will run it (vtec ecu for a vtec engine, non-vtec for non-vtec).
Old 11-27-2006, 05:22 PM
will any DOHC engines work with my Stock tranny!!!!
Old 11-27-2006, 05:56 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
only d series engines will bolt to you d series tranny.... sry....
Old 11-28-2006, 11:36 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
save for a B series....its probably the best way to go, although the D15b is kind of a fun little engine....we put one in my little brother's 98 Civic EX
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-02-2006, 06:02 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
http://www.honda-tech.com/zerothread/878010
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
