Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-14-2006, 04:24 PM
Killa's Avatar
Killa Killa is offline
What is this belt ?
Hi I just got the car back from the dealer ( new transfercase and new yoke this time ) they dont replace the yoke last time, so it leak again, now they have to give me new transfer case and new yoke, any way, i got under the car to change the transfer case fluid ( I dont trust wat dealer put on it ), I found the belt that under power steeling belt, that belt is really worm out, it about to brake, what is that belt call. I new power steeling belt is on top, and alternator belt is on middle and what the last belt call ? thanks
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-14-2006, 04:32 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: What is this belt ?
There's only 2 belts and then the timing belt. There's the alternator belt, then the power steering/AC. Those are on the main crank pully. Then behind that is the timing belt. I don't think you can see that from the bottom.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-14-2006, 04:43 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Wrong. One belt is for the alternator and power steering (Thats the one you can see from the engine bay) And the second belt (thats the one that can be seen from underneath) is for the AC...Unless the 7-bolt is different...
Old 11-14-2006, 04:57 PM
david-b's Avatar
Dave is THAT guy
Ahh, I figured the layout was the same as the 420a. The alt belt is on it's own.
75 Monte Carlo
Old 11-14-2006, 07:45 PM
Killa's Avatar
what happent if the A/C belt brake ? any damage to the engine ?
GM FOR LIFE !!
95 camaro lt1
Old 11-14-2006, 08:38 PM
If the Ac belt snaps it might whip up and break something. You might as well go ahead and change it or just cut it for now. Better safe than sorry!
Old 11-14-2006, 10:32 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
No it won't break anything, you actually might see a small increase in rev quickness because its less of a strain on the motor, but I'd just replace it and be on your way. IIRC, it's a PITA to get at the tensioner.
95 Talon TSI AWD
97 Eclipse GST
Old 11-14-2006, 10:38 PM
Killa's Avatar
should I get mitsubishi belt or just anything at autozone, any recomment brand ?
GM FOR LIFE !!
95 camaro lt1
Old 11-14-2006, 10:41 PM
Any belt should work fine. No sense spending more money on a part that will work the same from any manufacturer.
95 Talon TSI AWD
97 Eclipse GST
Old 11-14-2006, 11:01 PM
david-b's Avatar
Dave is THAT guy
OEM Mitsubishi brand belts have a less of a chance to sqeak when wet though. Most belts from the store have the grooves and are cut on diagonals while the OEM is usually just the grooves.
75 Monte Carlo
Old 11-16-2006, 11:25 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
don't buy a housebrand belt, actually spend the money and get a good one cuz pulling the motor halfway out is the easiest way to change that belt!
Don't act like you don't love it.
503/2000
Old 11-16-2006, 07:21 PM
I've ran all Napa brand belts except for the timing and have never had a problem with wear, cracking, or breaking. They're good belts. And pulling the motor halfway out is not the easiest way to change it you idiot. Why would that make it easier if you have to pull it out halfway? It may give you alot better access, but if you're a half-ass educated person that knows how to turn a wrench, it's not that hard to install it.
95 Talon TSI AWD
97 Eclipse GST
