Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 11-14-2006, 03:25 PM
89oldsregancy 89oldsregancy is offline
need help removing lights
if some one could help me. you know the lights on the side of the car inbetween the front and rear doors one of mine went out and is cracked so i can get one from a wreakers but i dont know how to remove it
Old 11-14-2006, 11:55 PM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
Re: need help removing lights
You have to open the door to get at this light. Open your door and just look at the area behind the light cover... you will definately see how to get at it... look all around that general area for screws. You must venture here.. you'll find a way, because there IS a way. Good luck
Old 11-16-2006, 07:46 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
This issue is well documented on a car on Cardomain.com but unfortunately I haven't found it yet. However, I seem to remember that there are some phillips head scews on each side (facing the door). If I remember wrong on that one, then you'll need to remove the inner plastic trim on the pillar on the inside of the cabin. From there, you should be able to pull out the light. There isn't a bulb, the whole thing is chemical based as I remember and you have to either get a new one from the dealer or get lucky at a junkyard.
If I find the cardomain site, then I'll post the link.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 12-29-2006, 06:18 AM
Drewet88 Drewet88 is offline
i'm going through the same problem did you find a way to get yours fixed?
O sorry 4 reviving the old thread..
(\__/)
(='.'=) This is the original Bunny. Copy and paste bunny
(")_(") into your signature to help him gain world domination
*1987 Oldsmobile Ninety-Eight Regency Brougham.*
(deceased)
*2003 Ford Mustang GT*
just a CAI and Exhaust...for now
Old 12-29-2006, 09:22 PM
nop im going to wait till summer until i get into the body work on my car
Old 12-30-2006, 02:41 AM
damn... dat sucks i guess i'll keep searching for a way to do it. I think the car would look really really really good if i could get them to work.
(\__/)
(deceased)
Old 12-31-2006, 01:21 PM
Alibi's Avatar
Hey, I think I remember. You have to remove the large flat plastic trim piece on the backside of the pillar to get at it. This involves removing the plastic trim around the doors (some of it, at least).
-Eric
Old 12-31-2006, 05:27 PM
so ill most likely have to go to the stealership in order to get the lights... autozone didnt have them and i'm not to sure if i trust junkyard lights.
(\__/)
(deceased)
