Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-14-2006, 09:44 AM
su_jumptd su_jumptd is offline
HELP!! Trying to track down the pinging source.
I’ve been trying to track down the source to the pinging sound on acceleration in my 2001 Honda Passport (V6). I did some research and came up with this (below); I’ve ruled out the 1st theory because I don’t have an overheating problem, and also the 4th theory because as I understand it the ignition timing on these year and type vehicles is computerized and is not manually adjustable. So that leaves me with the 2nd & 3rd theory. If I were to make an educated guess I think it would probably be the 3rd theory (EGR malfunction)……problem is….I can’t see nor do I know where the EGR is on my vehicle. I know it looks like a black can with some tubing and/or wires coming out of it. But, I can’t see anything like that nor do I know where to look…or even maybe this vehicle does not have one? Pictures would really help if not a general direction would be very helpful. Thanks in advance to all.
Pinging, knocking and detonation are all terms for a condition known as "pre-ignition". That means some of the gas and air mixture is igniting in the cylinder before it's supposed to. And when that extra flame front crashes into the normal flame front (created by the spark plug), you hear a noise, and that noise is pinging.
There are four major causes of pinging. The first three are related to excessive heat.
The first is severe engine overheating. If the engine is running too hot for any reason, the temperature in the cylinders can simply be too high. In that case, some of the mixture can ignite before the spark plug fires just from the intense heat.
The second major cause of pinging is carbon buildup inside the cylinders and on the pistons. When too much carbon collects, it can reduce the size of the cylinders (increasing the compression and temperature of the cylinder contents) and retain excessive heat itself.
The third cause of pinging is a malfunctioning exhaust gas recirculation (EGR) system. The EGR is supposed to send non-combustible exhaust gas into the cylinders to lower the temperature of the mixture.
How does 800-degree exhaust gas LOWER the temperature in the cylinders? Because it doesn't burn, and it crowds out some of the oxygen that would have burned and made an even hotter flame. And if that EGR is not working properly, the cylinder temperature can be too hot and the engine can ping.
And finally, incorrect ignition timing can cause pinging. The ignition timing determines when the spark plugs fire. And if they're set to fire too early, the stuff will begin to burn too early.
The use of higher-octane gas often makes the pinging stop because it has a higher ignition point. By requiring a higher temperature to make the gasoline burn, you reduce the likelihood of it "pre-igniting" somewhere else in the cylinder.
But premium gas doesn't address the underlying problem. So start by checking the EGR system, the cooling system and the ignition timing. And if none of those things fix it, then you can consider using a higher-octane fuel.
Old 11-14-2006, 12:28 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: HELP!! Trying to track down the pinging source.
http://isuzufaq.ibctech.ca/#faq3
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-14-2006, 09:56 PM
rodeo02 rodeo02 is offline
A pinging 1998+ is a stubborn mofo to troubleshoot. EGR shuts off on hard acceleration, so that's pretty much out of the picture. 2000+ 3.2/3.5's have electronic throttle control and a pretty involved ion sensing coil over ignition system, so any issues there will throw a code. If it were mine, I'd run some chevron techron concentrate, fuel power or lucas UCL, and do a spray cleaning of the MAF, throttle body, EGR and PCV and IAT sensor. Still pinging heavily after that, I'd order a new set of denso sprark plugs from sparkplugs.com. Still pinging after that? Let it be. I've yet to hear of a melted piston top on a 3.2/3.5 anyway.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-14-2006, 10:33 PM
Isuzu Guy
change the plugs recently?
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-15-2006, 07:47 AM
I took the EGR off and took a look at it. It seemed to be in good working order, the intake valve was free and clear..had a little builtup carbon on it but is still move nice and smooth. I'm still going to clean it out with some carb cleaner just in case. After that I looked around in the forum some more and ran across the sparkplug issue. I havn't changed the plugs in quite a while, so I went down to the local auto parts store and got some NGK Iridium IX (BKR5EIX-11). I hope these are the right kinda plugs...because the where $7 a pop. One more thing, would like to clean out the MAF, throttle body, EGR and PCV and IAT sensor. Can your give me a pointer on where these are located please. Thanks again for all the help.
Old 11-15-2006, 09:28 AM
Isuzu Guy
I would also think about dumping a bottle of techron concentrate int he gas and 1/2 a bottle of sea foam in the oil (right before you change the oil, put sea foam in and then take it for a short 20 minute drive and then change the oil).
The main thing that causes ping is the carbon build-up. If you take a look at your tail pipe you will notice the carbon build up on it.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-15-2006, 01:49 PM
Update: Changed the spark plugs, cleaned the EGR, Cleaned the PCV valve. Took it for a drive... I still have the dang valves clattering and clinging. The car drives well on take off but as soon as I get to about 35-40mph it starts pinging again. Also took it on the highway....does good....as long as you don't accelerate or go over a hill. As soon as the vehicle is accelerated or goes over a hill the valves spaz-out they cling, clatter and pings like a whiney B....th.
Old 11-15-2006, 02:04 PM
It's not the valves, it's spark knock/detonation you are hearing. I'd get a spray can of electronics cleaner (autozone sells CRC brand) and spray clean the MAF sensor and intake air temp/IAT sensor. Those two sensors can throw off the fuel trim just enough to cause a less than ideal air/fuel ratio. That condition could cause an audible ping as well.
Joel
Old 11-15-2006, 07:54 PM
trooperbc's Avatar
trooperbc trooperbc is offline
and if it's as bad as you're making out...i'd get it resolved sooner than later.
mild occasional pinging is one thing, raucous ongoing pinging is another and can end up harming your engine.,
.//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 11-16-2006, 12:54 AM
Ramblin Fever Ramblin Fever is offline
My '97 Rodeo 3.2L pinged for years; from the 1st day I drove it off the lot new. Did everything - plugs, filters, fuel additives, higher fuel octane, dealership even flashed the computer 4 times, pcv valve, you name it, we tried it.
For over 5yrs the truck ran with a ping at the slightest edge of throttle; out of pure luck we found what it likes = higher altitude. Sounds weird, I know, but the weekend we moved ourselves back to Colorado, that truck stopped pinging exactly half-way through Utah.
Been back here almost 6yrs now, truck has 164k miles and hasn't skipped a beat, the pinging for 5yrs/70k miles doesn't seem to have any long-term effect on my engine. Hasn't pinged a single 2nd in 6yrs.
Don't know what to tell you - as I never found an actual resolution when I was living at sea level; and you can't tell me that a new truck has enough carbon build-up to cause a pinging issue.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 11-16-2006, 07:52 AM
HI JOHN HI JOHN is offline
Talking Re: HELP!! Trying to track down the pinging source.
I found this web page that has info on the rodeos.
Engine noise: Ticking noise from the top of 3.2L V6 engine may be due to hydraulic lash adjuster failure caused by varnish deposits and using 0W-30 Mobil I synthetic oil has been successful in cleaning them. (1997-earlier)
If you are interested in reading the whole review here is the link. Good luck.
http://auto.consumerguide.com/Auto/U...reviewshowall/
PS. I have the same noise coming from the engine but I just found this info. I'll change my oil next time and will let you guys know how it went with the ticking.opcorn:
Old 11-16-2006, 11:24 AM
Originally Posted by HI JOHN
...Ticking noise from the top of 3.2L V6 engine may be due to hydraulic lash adjuster failure caused by varnish deposits and using 0W-30 Mobil I synthetic oil has been successful in cleaning them. (1997-earlier)..
The original poster has a 2001 3.2L. Totally different top end than the <1997. No HLA's.
Joel
Old 11-16-2006, 06:59 PM
trooperbc's Avatar
Originally Posted by Ramblin Fever
For over 5yrs the truck ran with a ping at the slightest edge of throttle; out of pure luck we found what it likes = higher altitude. Sounds weird, I know, but the weekend we moved ourselves back to Colorado, that truck stopped pinging exactly half-way through Utah. .....
well assuming it wan't the mormon influence half way through utah, i'd be inclined to think that the ManifoldAbsolutePressure (MAP) sensor was at fault (did yours have one?) or whatever other component measures altitude (barometric pressure) to help the computer in adjusting timing and fuel, etc. of course, maybe the computer was programmed weird, too.
maybe that's something to check out in this case...(?)
Old 11-17-2006, 09:53 AM
I"ll be more then happy to clean out the "MAF sensor" and the "intake air temp/IAT sensor" I know the rough loacation of these compnents but could some one point me in the right direction. A short discription on how they look and where they are located will be much appriciated. As pay back I will take a pic of all these components and post them, so other may benefit. Thanks again.
Old 11-17-2006, 11:01 AM
Real easy. The MAF and IAT sensor are the only two items in the air intake hose between the airfilter box and the throttle body. As far as I know, there is no MAP sensor on the 1998+ 3.2's.
Joel
