Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-13-2006, 11:20 PM
OrangeMushroom's Avatar
OrangeMushroom OrangeMushroom is offline
2000 2.5 Heater Fan Only Works on High
Blower motor only works on "high" on my 2000 Wrangler 2.5
Any ideas?
Old 11-14-2006, 09:37 AM
tomvid tomvid is offline
Re: 2000 2.5 Heater Fan Only Works on High
I have come across this in other vehicles but not on my Jeep. In my other vehicle I had somewhat of the same problem. It would only work on the two last high settings. Turned out to be the blower motor switch. It is a little switch, kind of like a curcuit board that has five on board leads on it. The five meaning the five different blower settings. Three of the leads on the board were wore out causing only the non worn leads to work with the blower. I have had to replace this twice on the same vehicle. Again, not sure if it will be the same with the Wrangle but it is worth a look.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
Old 11-14-2006, 01:18 PM
BLAZERBOY69 BLAZERBOY69 is offline
Smile Re: 2000 2.5 Heater Fan Only Works on High
IT IS DIFFERENT ON THE WRANGLER. YOU NEED TO REPLACE THE SWITCH THAT THE BLOWER KNOB IS ATTACHE TO. IT IS A BEAR TO GET OUT OF THE CLIMATE CONTROL CENTER, AND THE ONLY PLACE I'VE FOUND THAT HAS THEM IS A PICK N PULL. YOU COULD TRY AUTO ZONE, OR SOME OTHER SUCH, BUT IF YOU GO TO THE DEALER, THEY TRY TO SELL YOU THE ENTIRE CLIMAT CONTROL.
Old 11-15-2006, 02:11 PM
Thanks, guys.
