Old 11-13-2006, 09:41 PM
m3gumby m3gumby is offline
Interrior Dissasembly
Hey guys,
I just need to know if yall have any websites that show how to take apart the interrior of a 99 silverado ext cab. Im goin to put fatmat down to reduce road noise. I just need to take out the seats, center console, rear seat, and carpet. I 've taken out the rear seat, that Isn't hard, but just need to know anything i might come across. Anything will help. Thanks guys.
Old 11-14-2006, 08:05 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: Interrior Dissasembly
Don't know a diagram, but it really shouldn't be all the hard. Just move one piece at a time, bolt by bolt. I would separate out the bolts into differnent baggies though.
*Under Construction - New sig to debut*
Old 11-15-2006, 05:40 PM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
you will need a 7mm (I think) socket or nut driver for the door panels etc. most all the interior screws are the same size. so geta baggy and collect them all. Also a lot of the parts just "pop" off. make sure you thoroughly inspect for screws though before trying to pry. If you stress this plastic a little too much you get a white spot in th eplastic that appears and will never go away.
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
Old 11-16-2006, 08:38 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
the top of the console will pop off and then there will be some 10 mm bolts that take it loose from the floor and the seats just unbolt and remove and trim panels along door seal will just pop up. then pull out carpet should be a fairly easy task. i did the same thing putting sound deadening all over and made a huge difference.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 11-17-2006, 07:32 AM
fleettech fleettech is offline
disconnect the battery and wait a little bit before disconnecting wiring just to be on the safe side it would suck to get rolled out of it by a deploying airbag
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
