Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-13-2006, 09:21 PM
hagman hagman is offline
sc clunks and growls upon in first upon rapid acceleration
I replaced the two struts cw hubs. Saturn runs smooth in each gear (5 speed). If I start out normally (accelerate normally) everything is fine, however if I accelerate quickly, there is a clunk and grinding, I am not sure if it is in the tranny, bearing or cv joint.
I can take it to the shop to have it diagnosed, ($$$$$) or perhaps someone can suggest where to start.
Thanks
Hasgman
Old 11-14-2006, 05:41 PM
samprix samprix is offline
Re: sc clunks and growls upon in first upon rapid acceleration
I had a similar problem with me 95 SL2. Turned out to be the top motor mount on the passenger side of the car. I'd check that first. I started by replacing the struts. I coulda saved a bundle if ida check the mounts first.
Hope this helps. Good luck.
Old 11-19-2006, 08:25 AM
Thanks
I'll give that a try
