Old 11-13-2006, 08:46 PM
robroy55 robroy55 is offline
Auto Down drivers window Question
For some reason, my auto down feature does not work in my 2002 SES duratec. Any suggestions??
Thanks Folks!!
Rob Roy
Old 11-13-2006, 09:05 PM
reekor reekor is offline
Re: Auto Down drivers window Question
Check or replace the module in the driver's door.
Thanks Folks!!
Rob Roy
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 11-14-2006, 12:35 AM
MyTaurus8AChevy's Avatar
MyTaurus8AChevy MyTaurus8AChevy is offline
Smile Re: Auto Down drivers window Question
Ordinarily it's just a bad switch, which you should be able to test with a meter, but I think it also goes to the GEM. I'll look at the wiring diagram tomorrow for you. You probably won't be able to buy just one switch, they most likely want you to replace the whole assembly so you might want to check the bone yard for parts too, but first let's find out for sure what is wrong
Old 11-14-2006, 09:38 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Yep, the Generic Electronic Module (GEM) controls the One-Touch Down (OTD) relay. Either could be faulty, but it would certainly be nice if it's only the relay. Power to the OTD relay coil is provided by an accessory relay as well. Other functions should fail to work if the accessory relay is faulty. There is a separate pole in the driver's window switch to activate the OTD feature through the GEM, so you'll need to check that circuit out as well.
If you hold the button to roll the window down, it works fine, just not the one-touch down? Did it ever work for you (so you know you're trying to activate it correctly)?
Are you familiar with relays and understand how to test them? The OTD relay is located in the Central Junction Box.
-Rod
Old 11-16-2006, 09:33 AM
I too am curious if this ever worked. I just bought the (factory) service manual for this car so if you still can't get it working let us know, and I can post what it says about troubleshooting that part
