Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-13-2006, 08:48 PM
Peter Ma Peter Ma is offline
engine shuts down in the middle of the street
ok, eclipse RS, driving in the middle of the street, engine goes from 500 rpm to 0 rpm then just shuts down itself, i have to constantly pumping gas into it to make it run, or turn the heater on at max lvl.
also, when u put on neutral to reverse, or neutral th drive, there is a 'burp' sound
does anything sound familiar?
Old 11-13-2006, 10:20 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: engine shuts down in the middle of the street
Have you disconneted your battery recently? I know it takes a few starts for the computer to reset itself an get the idle correct, but it usually does not affect the engine under driving, just when it idles. Other than that idk. No check engine light?
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 11-14-2006, 01:46 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
throttle position sensor? make sure your throttle cable is tight
then start checking spark, air and fuel
Don't act like you don't love it.
503/2000
Old 11-16-2006, 04:08 PM
hansonboy6330 hansonboy6330 is offline
Mine is doing that too... I just disconnected my battery yesterday for ~45 minutes and it's dying when idling... It's been like that after a few starts... What else can i do?
like should i disconnect it again and try again?
Old 11-16-2006, 05:28 PM
rodbls's Avatar
No, just let it be. If you disconect the battery again it will restart the cycle. It needs like 5-10 starts to reset the computer and get your idle right. It will fix itself.
