Old 11-13-2006, 07:10 PM
dmacl dmacl is offline
1994 blazer steering shaft moves fiber spacer
having a problem with loose front end. replacer pitman arm and old steering box. tightered up a lot but steering whel moves back and forth. read a thread on replacing shaft with on from a jeep but it was for a 95 and up. he said one from a wrangler would work for pre 94 has anyone done this and have photos and info on it? thanks
Old 11-15-2006, 08:31 AM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
Re: 1994 blazer steering shaft moves fiber spacer
Its the rag joint that is worn out. Im not sure if the 94 is the same as 95 or not.
The best way to go IMOP is to get a solid shaft instead of one with the rag joint as it will just wear out again.
On a side note, I turned mine into a solid one by bolting through the rag joint in four places. I wouldnt recomend this because if you screw it up you could loose the ability to steer your vehicle.
