96 Grand Am Instrument Gages Going Crazy???
SO I HAVE A 96 GRAND AM WITH THE INSTRUMENT GAES GOING CRAZY. I CHECKED THE FUSES AND BATTERY AND THAT DIDN'T HELP. i WAS TOLD IT MAY BE THE BCM (BODY CONTROL MODULE) i JUST WANTED TO KNOW IF ANYBODY NEW WHERE TO GET ONE AND WHERE THEY ARE LOCATED...OR IF YOU HAVE ANY OTHER IDEAS
Re: 96 Grand Am Instrument Gages Going Crazy???
![]() But yeah that's happened to me before, I'd like to see if anyone else has an answer
Current: 2012 Toyota Rav4 3.5L V6 AWD Current: 2018 Tesla Model 3 LR AWD + Accel Boost Past: 1999 Pontiac Grand Am SE (sold 2013) Past: 2007 Mazdaspeed 6 Grand Touring (sold 2016) Past: 2009 Subaru Legacy 2.5i Special Edition (sold 2019) |
Reading my crystalball;
I seee a new dash cluster ![]() Thier is a couple years that have this trouble, 94-96 , For some reason they just crap out, most likly due to bad solder joints/ciruits. Your best bet is to check local salvage yards, then hit ebay for a used one(that works of coarse) for around $50ish. Just remember to disconnect the battery when you remove and replace the cluster. Hope that helps, and Welcome to AF ! btw please kill the caps, its like you are yelling
1999 Grand Am SS 3.4 OHV
so is there any thing else it could be...i'll try that first
Not realy.
You can check all you fuses and maybe the wiring to the dash cluster, but its most likly your cluster is just going out.
do you have do reprogram the thing....because i got one and once i put it in i could not start my car
Yes sometimes you do need to do a relearn procedure.
Turn the key to the "on" position and leave it on for at least 10min, Leave it off for 1-2 min. You might have to repeat this 3 times. You should see the security light come on(if its not already) or flash then go out when its done.
Hell yeah !!!! i can do it myself? gm wants a 100$ to do that...can i get a step by step to relearn it or is it really that easy
thanks |
it is that simple.
It can take up to three trys, and sometimes it'll relearn it in one. The dealer just figures the full time on it so $100 is about right for 1.5hrs of work.
I just replaced the gauge cluster on my 96 GA also. Now I am having problems with the anti theft system. Sometimes it starts and sometimes it doesn't. My question is, when I go thru the relearn procedure and wait for the anti theft light to quit blinking, is it supposed to just quit blinking or go out? I have had both happen. And sometimes it blinks 5 or 6 six times and quits. Even after it quits blinking I can't always start the car. Doesn't seem the be a pattern that I can see. Dealer is telling me I need to replace the ignition switch. Is that legitimate thing? The car has 128K miles.
Welcome to AF marvinrb !
Sorry if I wasnt clear on that security light, it should go out after flashing 5-6X. IF the ignition switch is bad then yes it would need replaced, and could be why you are having trouble with the security system. try the relearn 3X , if the security light doesnt go out then you have other issues. Hope that helped!
