Go Back   Automotive Forums Car Chat > Daewoo > Leganza
Old 11-13-2006, 03:53 PM
Bob Rutzel Bob Rutzel is offline
Smile Heat Problem Solved
I posted before explaining I had no heat in my 1999 Leganza, and figured a new thread with the solution would get the most attention.
I now have hot heat. The Heater Core was not in the proper position. There is a clip that holds it in place and somehow the Heater Core popped out and this did not allow the heat to go thru. So if anyone still has this problem check the clip that holds the heater core in place.
Hope this helps
Thanks to all who offered their ideas re this problem. Thanks again.
Bob Rutzel
Old 01-04-2010, 04:43 PM
hikouka71 hikouka71 is offline
Re: Heat Problem Solved
hi, sorry to blast from the past like this, but i've been trying to figure out my gf leganza that has plenty of flow but little heat, i got the glovebox out and can see various components of the airbox setup but no idea where to look for the heater core to see if its come unclipped like yours, was hoping you could give a little guidance, shame you didn't get pics of when you were doing the job
thanks for any help you can give
