Old 11-13-2006, 02:20 PM
loribythesea loribythesea is offline
Does anyone have a wiring diagram for '96 window controls?
Hi all! My driver's side window won't roll up, the underside of the switch is corroded so I'm thinking it fizzled out. It rolled up intemittently before it stayed down the last time for good. At the moment I don't have the money for the part and just want to bypass the switch and get it rolled up. We had our first snow yesterday and it's so cold to drive!
So, if anyone has a wiring diagram, or can even just explain which one will roll the window up, that would be so great. I already know which one is the hot one, so I'm alright there.
Thanks in advance! - Lori
My e-mail is [email protected]
Old 11-13-2006, 02:36 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Does anyone have a wiring diagram for '96 window controls?
Light green is up and white is down. Tan is the power source. Black is ground. Measure the resistance from lt green to white to measure across the motor windings. Open indicates a fried motor or broken wire. I'm picturing you with a connector disconnected from the switch assembly. Don't forget to ground the white wire as you apply power to the light green.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-13-2006, 07:12 PM
1thunder 1thunder is offline
Good info RIP and if he puts 12v to the green and jumps the white to ground so long as the motor is ok it should go up
Old 11-13-2006, 07:25 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Uh oh! loribythesea is a she. Be ready to suffer the rath.
Yup. Should have said jump white to black then touch tan to green. Lots clearer. Cheers!
Old 11-13-2006, 10:55 PM
Ha! That's okay, forgiven. Thanks a ton for the info. A bit of unexpected rain got into it so I'm gonna wait for it to dry out before I give it a try. I will definitely post the results. -Lori
Old 11-14-2006, 04:34 PM
KimMG KimMG is offline
AF - Advisor
check out autozone.com they have free repair guides with wiring diagrams.
Can you trade the passenger window switch with the bad one?
